SkiingSixPack
Aug 17, 2013Explorer
Reddog1 has it right (as usual). Do not turn the unit over.
Are you certain the unit is leaking because of the seal? Does it leak only when raining? If so, then maybe it is from a bad seal.
But, if it leaks when not raining and the unit is running, I would say that it is not the seal... then look at all the other possible culprits. Plugged drain hose, unit icing up and then thawing, etc. Searching the posts will help lead you in the right way.
Just my $.02 Good luck!!!
44,027 PostsLatest Activity: Mar 05, 2025
