Bleugoat's avatar
Bleugoat
Polar Cub Gasket Install Question
I have a leak around my Polar Cub A/C. I need to tip the A/C unit over to remove the old gasket and install a new one. It appears that the shroud needs to be in place when I tip it over.
Will the shroud support the A/C when tipped over? The plastic shroud is pretty flimsy, but when I remove it there is really no framework to protect the coils, etc. when tipping over.
The roof on my Apex is flat, so while I have the A/C off I am going to build up the A/C opening with 1/2" plywood and eternabond tape to provide better drainage.
The question is: should I leave the shroud on while tipping the A/C over?
