brebar's avatar
brebar
Polarity Checkers
Hello everyone. I have a question about using a standard house polarity checker with a 30 amp adapter, to check polarity at the pedestal.
I am a new owner of a TT and I have been researching surge protectors. Some of the “surge protectors” look like fancy and expensive polarity checkers.
I know I could ask the dealer about this, but I thought that another newbie might benefit from this question.
Thanks!
  • Ok, let me clarify my question.
    I have a standard house current polarity checker. It indicates an open ground, open neutral, open hot, hot/ground reverse conditions. It has three indicator lights that will light up in a certain sequence, depending on the wiring condition of the duplex. It has a 120VAC 15amp three prong on it for use in checking wiring conditions.
    I can buy a 15 amp (female) to 30 amp (male) adapter for around $5, and install it on my (house hold) polarity checker.
    My question is, can I use this to check for proper 30 amp wiring, (open ground etc.) at the campground pedestal?
    Thanks!
  • RoyB's avatar
    RoyB
    Explorer III
    The so called expensive SURGE PROTECTOR plays a very important role in the RV trailers. It is always ON and looks for bad incoming 120VAC line voltages. When it see's something bad it disconnects your RV trailer from the source to prevent failures.
    Actually a small price to pay for protection like this...
    You can use RV adapters to get your 30A and 50A service pedestal down to a 20AMP Receptacle and plug in one of these CIRCUIT TESTERs which will detect bad wiring and possible problem areas but does not give you 24HR protection. These are really just a good tool to have around to test the 12VAC Power SOURCE before you hook-up to it.
    I think this is what you may be referring to...
    Roy Ken
