CdaddyExplorerJun 10, 2017Power outlets not working on battery powerOur 2016 heartland trailer plug outlets do not work when I'm on battery power only shore power. Is there anything I can do to change this?
parcanyExplorerJun 10, 2017They are for 120 volts and not 12 volts. When the trailer is plugged in then you can use the trailer plugs.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problemNot all Aftermarket bumpers work
