Tongue weight is not the issue for a tongue jack. Keep in mind that you will be lifting the rear of the tow vehicle to instal the weight distribution bars. I do not believe that there is such a thing as too much jack. I also would not recommend anything less than a 2k pound capacity jack. The heavier your tow vehicle is the bigger capacity jack that you will need.
- Grit_dogApr 07, 2024Trailblazer
You’re assuming he’s using wd bars? That trailer is dinky and lightweight. Maybe OP has a midsize suv for towing but if it’s a full size anything, wd hitch is not needed at all.
idk why an electric jack would be any sort of measurable advantage on such a small trailer.- valhalla360Apr 07, 2024Navigator
Maybe he has rotator cuff issues...the point is even the lightest duty electric jacks will have no issue lifting the tongue plus a bit of weight off the back of the truck. If not using a WDH, it's even easier on the jack.
- valhalla360Mar 24, 2024Navigator
Agreed, lifting the back of the truck a bit to relieve stress on the bars is likely the bulk of the load but on the other hand, even the weaker jacks are rated for 3500lb, so not likely to be an issue. It's not like you want to lift the rear axle of the truck off the ground, just take a few inches from the springs.
