RoyB
Mar 13, 2016Explorer II
Just be mindful that DOT requires your trailer to have a 12V battery for your emergency break-away cable to stop a run-away trailer if it becomes disconnected when being towed. This is a DOT law...
Although you can just run off the 12VDC coming from the on-board converter/charger unit when on shore power having the batteries connected sort of smooths everything out. If your on-board converter/charger unit is a smart mode system it will automatically keep you battery charged-up without incident..
If you only have a 13.6VDC single mode charger on-board then it would be wise to check your battery fluids on a scheduled basis as this DC voltage is known to boil out your battery fluids over time which will destroy your battery...
Roy Ken
Roy Ken
44,056 PostsLatest Activity: May 04, 2014
