imq707s
Oct 12, 2016Explorer
Preventative Maintenance on 100,000+ mile Tow Vehicle
My 04’ Ram 1500 Hemi Quad Cab 4x4 has been a great truck…..140,000 miles on it and the only issues I’ve ever had as far as part failures were an EGR valve, ball joints, and a front wheel bearing.
Recently on my with my family, I was pulling our 19ft camper trailer back home (around 4,000lbs) when something let loose in the rearend and chewed the hell out of the gears. In order to get us home, I ended up having to have a rebuilt rearend put in…..not cheap. I think it must have been a fluke deal, because those 9.25” rearends are supposed to be bullet proof…..and I keep my truck maintained very well as far as fresh fluids. Long story short…we were stranded for 4 days, 500 miles away from home with a 14month old.
So that got me thinking……I have no plans on getting rid of my truck any time soon(should I?), and over the next several years I plan on taking our trailer on many more trips across the country. What items should I replace as “preventative maintence”? Things that could go bad, might go bad, or are pretty common to wear out when towing long distances?
It’s got the stock oem fuel pump……should I think about replacing it?
How long are they good for?
It’s got the stock u-joints on the rear driveshaft. Should I replace those before they leave me stranded?
It’s got the stock front CV joint axles. How long do those usually last?
How long should the 5.7 Hemi last?
Should I have the 545RFE transmission rebuilt? Nothing wrong with it….but how long do they usually last? Should I put an aftermarket cooler on the transmission lines in addition to the oem cooler?
You get the idea……
When the rearend whet out and I was stranded with my family for 4 days and 6 hours away from home…it was a nightmare. I want to do as much as I can to prevent something like that from happening again. I’m a little spooked now to say the last……don’t want to go through that whole ordeal again if I can help it. Not sure I could have done anything to prevent the rearend from eating itself….I Think that was just a heavy dose of bad luck.
You get the idea……
[/img]
