NCMODELA's avatar
NCMODELA
Primus IQ Questions
Two questions for the primus IQ owners. There are two brackets one has pre-slot brackets for up down adjustment, the other metal you can adjust all the way by just tilting. I put in the pre-set one, has anyone had trouble going up or down a mountain side with the preset one because there are only 3 adjustments.
Second, under deceleration with out the brakes applied will the primus IQ be slowing the trailer down with the trailer brakes or does it only work when brakes are being applied?
1 Reply
  • Mine is mounted upward. Never had trouble up or down grades.
    Secondly, the brake controllers are activated by brake light switch. No braking on the TV, no braking on the trailer.
