Jeffzee160 wrote:
This thread gave me an idea.  I couldn't use baggage door latches because my window hinges don't swing up past 90 degrees.  I made some prop stick extension from PVC pipe.  The pipe simply slips over the window's existing prop stick.  On the other end of the pipe I added a 45 degree elbow that I cut down into the shape of a tab.  The tab slips into the existing window frame notch.  Not sure I'd leave this set up in gusty winds, but...
The rest of my dumb ideas are at...
http://www.jeff-z.com/rv/amods/amods.html
I like this idea.  May try it.  I was also thinking of getting latches like the ones that would hold the legs of a tv tray or similar table open.  Thanks for the pvc idea.
