blt2ski
Feb 09, 2015Moderator
john&bet wrote:dodge guy wrote:This does not explain why two identical trucks, same years, same model, same cab configuration, why one has them and one does not. Only difference is one is a 4x4 and the other is a 4x2.
The 3 center lights indicate a width of over 80" the 2 outer lights indicate the corners of the wider load.
There is also a height requirement IIRC, along with, you could special order them as an extra. Sometimes in the past, a camper special would have them also, as this would be required due to the overall width assuming a bed camper was installed.
For some, I can see this as bling, others of us, a requirement depending upon HOW we are using the truck and trailer.
Marty
