Atlee wrote:
Why doesn't the Gross Vehicle Weight Rating equal the Gross Axle Weight Rating for the front and rear axle?
Looking at Fords builders spec pages , even Ford say it may;
4) Gross Axle Weight Rating is determined by the rated capacity of the minimum component of the axle system (axle, computer-selected springs,
wheels, tires) of a specific vehicle. Front and rear GAWRs will, in all cases, sum to a number equal to or greater than the GVWR for the particular vehicle."
Lots of RV folks are confused by how much brake performance a vehicle has. Especially our trucks. Brakes are a function of the vehicles axle system.
NHTSA says this about components of the GAWR:
"Gross Axle Weight Rating is the rated load-carrying capacity of an individual axle and wheel assembly. (It represents the load that may be steadily sustained by the components in the system; i.e., tires, rims, hubs, bearing, axles, brakes, suspension, sub frame, etc. with the GAWR limited by the components with the lowest working rating".
and from RMA
• GAWR: Gross Axle Weight Rating (for each axle) -
The maximum weight rating that the components
(tires, rims/wheels, brakes, springs, and axle) of
each axle are designed to support. This is
determined by the lowest design capacity of any
component. In other words, if the wheels have the
lowest design capacity of any component on that
axle, installing tires with a higher load capacity
does not increase the GAWR. By regulation, the
tire load rating times the number of tires on that
axle must equal or exceed the GAWR for that axle.
And for our trailers;
dexter axle;
The Gross Axle Weight Rating (GAWR) of your running gear is determined by the lowest rated component in the assembly. The capacity of the wheel, tire, axle, brake, springs/rubber and hub are all considered.
