Brettmm92's avatar
Brettmm92
Question about solar panels
Hello,
I had a question about solar panels, specifically if they can hook up to the battery that's included on the trailer tongue. Ive never used the battery that came with my TT because it was dead when I bought it. But I noticed that it has specific wiring into the TT. Can I hook a solar panel up to that battery and then possibly use more batteries in a series to power my TT?
If that wouldn't work, where do you plug in battery banks for solar? I've seen videos of TV's that seemed to have extra, even labeled solar power accessories, but mine does not.
Thanks ahead of time for any input!
  • Do you plan to camp w/o hookups? If you're looking at solar it would be a good time to get 2 6-volt golf cart batteries and wire them in series.
  • "an inverter is needed to convert the dc power from the panels to ac."
    Panels charge the battery. The battery supplies the inverter.
  • Brettmm92 wrote:
    Another thing that I wish I put in the original question is that I'm aware an inverter is needed to convert the dc power from the panels to ac. Do the travel trailer wires that connect to the battery have their own inverter or something? And where would I install that? I'd imagine that I'd have to fiddle with the wiring inside as leaving an inverter outside sounds like a bad idea to me
    Inverter can be a bit complex depending on size. Less than 300 watts can be installed easy behind the breaker panel, use the main 12v connection for power, and connect to the panel with a transfer switch.
    If you are going 2000 watts you need four batteries minimum and inverter needs to be mounted close to the battery. Then pull wire to the breaker panel, drag your main cord around and plug in direct, or add an inverter outlet in the living space.
    Lots of ways to do this depending on your expectations.
  • However you wire it make sure you use the same type battery throughout the system and use about the same age. In your case, new.. Don’t mix 6v with 12v and don’t mix agm with lead acid, etc.
    I wired mine separate from the battery that came with the trailer. I have 4 6v gc for the coach and use the 12v only for the tongue jack and emergency brake. I use a trickle charger I got from academy to keep it charged. Works well, I just store it in the propane tank cover when rolling.
  • 4x4van's avatar
    4x4van
    Explorer III
    What are you planning on using the inverter for? Solar panels are dc, your battery is dc, most of your components in the trailer are dc (with the exception of your air conditioner, your microwave, and possibly your TV). Inverters convert 12vdc into 120VAC, and you need a very large battery bank to run anything other than small items from an inverter.
  • All the questions you asked are answered in great detail in other forum post. Use the Search function and read, read, read. You are just asking us to repeat what has already been asked, but without any details on what you plan, or if you even know what you want. You are just getting tid bits of info on this string...
    Is your "tongue" battery the big one, or are you talking about a small hold-in-your-hand battery which would be specifically only for the trailer brakes? You can get a ticket for not having 12 volts at the emergency break-away device for the brakes.
    After you read a few post on solar set-ups you can ask better questions if you still have any... There is everything you need to know on this forum
  • Brettmm92 wrote:
    Thanks for all the information!
    I definitely plan to get a battery, more so now since the emergency brake function is pretty important.
    I'm seeing some corrections that need to be made to your thoughts and explanations. This statement "convert the dc power from the panels to ac""convert the dc power from the panels to ac" is incorrect as the power is not from the panels. The power is from the battery bank. The panels and controller only charge the batterey bank.
    The inverter is or can be done in a couple ways. One way is to wire the 120v side(output)into your 120v system on you RV and has some kind of transfer switch associated with it so when you plug the trailer into shore power it doesn't fry the inverter. Another way is to kind of have the inverter as a stand alone source of 120v power. In either case, you want to get the inverter as close to the battery bank as possible and be real generous with the 12v wire size....Generous is not #6 or #4. Generous is like 1/0, 2/0 etc. This of course depends on the rating of the output of the inverter and how close it is to the battery bank,
