MG1912's avatar
MG1912
Question about tire pressure
My 2007 Ford F350 6.0 supercab long bed SRW has Nitto Terra Grappler G2 A/T LT295/70R18 E 129/126Q tires front and rear. The truck came with 275/70R18 LRE tires, which were replaced by the previous owner. I wrote to Nitto to ask them about recommended tire pressures for my truck camper application (~3,000 on front axle and ~7,000 on the rear axle). I received what seemed to me like a lawyerly response:
"Based on the information provided, the calculated pressure for your Terra Grappler G2 tires is 65 PSI cold pressure on the front tires and 68 PSI cold pressure on the rear tires. At these inflation pressures, your tires are supporting the same amount of weight as your OEM tires did per the vehicle manufacturer's specifications. For any increase in pressure due to towing, we would recommend referring to your vehicle owner's manual for any instructions."
I was surprised because I would have thought they'd recommend closer to 80 PSI for the rear tires. Is their response cautious due to liability concerns? The reference to OEM tires and the vehicle owner's manual makes me suspect this. Or do the recommended pressures sound right?
