wrvond wrote:
I think your awning is similar to mine. The switch simply says "in" and "out". The awning itself doesn't auto retract, nor does it have auto dump. Once it's deployed, I simply push down on one arm and tighten the knob to create a slope for rain run off.
Same here.
wrvond wrote:
These awnings don't come with braces that can be used to brace against tie down straps. However, it is a common mod to create legs that can be attached to the arms to brace against the pull of tie down straps. This mod works very well, too.
Did you make yours? They look very well done. The poles look extendable - are they long reach paint roller handles? l was looking at these to make mine but was not sure they'd be long enough. My awning roller is about 8' or more off the ground.
