Mumphry's avatar
Mumphry
Ram 2500 - 2014 vs 2015 Differences
I am considering a 2014 Ram 2500 still on the lot. Anyone know the differences in the:
1) chassis
2) axle
3) 6.4 engine.
It looks like the 14' has the five link rear end and the Multi Displacement System (cylinder deactivation) just like the 2015's.
  • bhall wrote:
    RoyJ wrote:
    Not sure about GM, but have you checked the door sticker of different models on the lot?
    That is how I purchased my 2015 Silverado 2500. My wife hates red and don't you know it, the red one had the highest payload rating at 2831 lbs of the 3 other 2500s on the lot that night.
    Do you have a diesel or gas 2500?
  • kaydeejay wrote:
    ib516 wrote:
    ..............Unlike the competition, Ram rates their payload including radio, console, and bumpers.
    What ARE you talking about?
    The Tire and loading info label is required by law on every truck since 2006.
    The "Occupant and cargo must not exceed" number is calculated for EACH truck AS BUILT and has to be accurate within 10#.
    So it includes the radio, console and bumpers!
    Now there has been some interesting marketing of MAXIMUM payload ratings which WERE values from a stripped (but theoretically orderable) configuration.
    Bottom line - check the label on the truck for the REAL number, regardless of manufacturer.
    I was talking about when Ford and GM were caught "fudging" their "max payload" numbers by quoting them for a truck without a:
    - rear bumper
    - spare tire
    - center console
    - jack and wheel wrench
    - radio and speaker(s)
    - and swapping in lighter aluminium wheels on trucks that come with steel wheels
    "The American automaker has said that it also removes heavy items from its pickup trucks when it weighs them to help boost the trucks’ maximum payload ratings. The company adopted the practice this year to stay competitive when it launched its redesigned full-sized pickups. Ford started using the tactic about four years ago, showing that the maximum payload is larger than would be possible if it used the standard base curb weight of the truck.
    Removing heavy items including the rear bumper and swapping out the heavier standard steel wheels for optional lighter alloy wheels, helps increase a truck’s maximum payload figure while keeping the same gross vehicle weight rating. GM spokesman Tom Wilkinson told Automotive News that the maximum payload claims on the 2015 Chevrolet Silverado 1500 and GMC Sierra 1500 are based on a minimum curb weight that deletes the rear bumper and spare tire. Ford said that the maximum payload claim on the weight of the base F-series is derived after various items are removed, not on the base curb weight of the F-series pickup.
    Chrysler has reaffirmed that the Ram brand uses the base curb weight of its pickups to establish the maximum payload capacities and doesn’t use a modified curb weight like Ford and GM."
    "Both automakers have acknowledged that they remove factory parts - including bumpers and spare tires, among other items - before calculating payload ratings on certain pickups. Without those components, curb weight is reduced, letting the companies tout higher payloads than are advisable with the actual unmodified trucks that buyers see in showrooms.
    Payloads ratings are devised by determining the difference between an automobile's gross vehicle weight rating (GVWR) and its unladen curb weight.
    Ford told Automotive News that it began using the practice in the 2011 model year with its F-250, F-350 and F-450 Super Duty pickups, removing items like the spare tire, jack, radio and center console.
    As AN notes, loading up an F-450 to its advertised payload capacity would cause the truck to exceed its GVWR by 61 pounds. But exceeding a vehicle's GVWR could lead Ford to void the warranty.
    In order to maintain "apples-to-apples" comparisons, GM decided to follow Ford's example and started taking off components such as the rear bumper before calculating payload ratings for its 2015 2500HD and 3500HD pickups.
    A number of dealers, including Mitchell Dale, president of McRee Ford in Dickinson, Texas, have voiced concern over the practice, which they feel could confuse consumers and erode buyer confidence.
    "When we're starting to remove items from the vehicle, it would be my expectation that all manufacturers do their testing with production line vehicles similar to what a customer would drive," Dale said.
    "We're so internally focused on having the bragging rights of whatever segment we're talking about that it appears that there are some questionable practices being done."
    For their part, Toyota and Ram have stated that they use stock pickups fitted with all standard components in order to calculate payload ratings."
    Read more: LINK
    Then the fallout and backpedal by GM a few days later:
    "Following last week's mild uproar after it was discovered that Ford and General Motors were removing some optional parts from their pickups to lower the curb weight and consequently increase the maximum payload, GM has come out and committed to a base curb weight for its upcoming Chevrolet Colorado and GMC Canyon compact trucks (although it has yet to publish them) and its current Silverado and Sierra. The company will do the same for its heavy duty offerings, although those numbers have not been finalized yet.
    "This will make our curb weight and payload specs more consistent with those of most other truck makers, making it easier for customers to compare vehicles," GM spokesman Tom Wilkinson told Autoblog in an emailed statement.
    As GM notes – and as every manufacturer has noted since this story broke – customers still shouldn't take max payload ratings as gospel. Instead, they should refer to their truck's Tire and Load Label, like the one shown at the inset, which will offer detailed information on max payload, specific to their truck.
    Automotive News, meanwhile, reports that Ford has not made any changes to the way it figures out max payload ratings, despite the GM announcement. The company was at the center of last week's news, when it was revealed that it removed items like the spare tire, jack, radio and even the center console, to determine the curb weight for the F-Series Super Duty."
    LINK
    It's not the actual payload (on the label) they were fudging, it was the max payload advertised numbers.
  • RoyJ wrote:
    Not sure about GM, but have you checked the door sticker of different models on the lot..................
    Don't have to check the labels - I was responsible for all of the the variable data* labels on GM products until I retired. So I KNOW the legal requirement behind those Tire labels. If any Manufacturer is NOT calculating payload for EACH vehicle, then they are breaking the law.
    * the ones with vehicle specific values - Certification, Tire loading, emission, price, to name but a few.
    BTW, Ford "cheated" to come up with a Maximum payload rating for a product range. It would have been theoretically possible for a customer to order a truck with the configuration that resulted in that max number - not that most folks would want to. So was it really "cheating" or simply misleading?
    It does not mean they were off the hook for calculating each specific vehicle's rating for the Tire label.
    You obviously missed the news how Ford cheated to come up with the payload numbers on the F450.
    Ram literally calculates it for EACH truck coming off the assembly line. Add a subwoofer? Yup, they re-calculate and lower the payload. Same goes of trailer hitches, sunroofs, etc.
  • No difference in the mechanicals and very little if any in the cosmetics. The big difference happened between the 2500 trucks from 12-13 and 13-14 model years. Note that 3500s are a little different.
    2013 - change over to use of def.. updated HP ratings, torque now at 800lbs (like 2012 high output version) chassis was carry over 2012 3500 chassis still had leaf springs on 2500. (Essentially a 2013 2500 is what a 2012 3500 was with minor differences)
    2014 - change frame, front end and add coil over multi-link springs in the back. Also available with auto-leveling air bag suspension. Also different wheels from 2013.
    2015 - no change
    The 3500s moved to the new frame in 2013 and still use leaf springs in the back.
  • The only differences are that the 15s have power folding trailer mirrors, the 14s are manual flip type. There are also a couple new paint color available in 2015.
    The Ram 3500 pickup with the 6.4 liter Hemi V8 engine gained 100 pounds in its gross vehicle weight, increased to 13,800 pounds. Unlike the competition, Ram rates their payload including radio, console, and bumpers.
    That's about all I found.
    There is no significant changes 2014 to 2015 that would make a person want to buy one over the other - like the ones you mention (chassis, axles, engine, etc.).
