- Taz_23ExplorerI liked the 2500 Ride better than the 3500. That being said, if you need or will need the payload in the future go with the 3500. Also know that the 2500 with the 6.4 is rated at 10,000 GVW and the 5.7 is rated at 9,000 GVW.
My 2015 2500CC with the 6.4 is rated for 2999 Lbs per door sticker. If I was going with a diesel I would opt for the 3500 because the additional weight of the motor and tranny = reduced pay load. - Grit_dogNavigator IIIMaybe go test drive them and see for yourself??
- Me_AgainExplorer III
bbaker2001 wrote:
my 3500 is bouncy empty, but ride good when loaded.
we went with the 3500 for cargo ability. look at the above posts about buying a 2500 just to find out it is not eneough
Put your rear tires down to 44-46 psi empty for an improved ride. Might ride better than a 2500 that can't have the tires lowered without alarming. Chris - bbaker2001Explorermy 3500 is bouncy empty, but ride good when loaded.
we went with the 3500 for cargo ability. look at the above posts about buying a 2500 just to find out it is not eneough - thecdnmoleExplorer
IDoMyOwnStunts wrote:
nor did they have one in either flavor equipped with air ride. If you can find one of those, I'd be interested to know the difference.
Yes, actually the 3500 I am looking at has the air ride, so that might help a bit. - IDoMyOwnStuntsExplorerWhen I was shopping for this one, the ride difference between a 2500 we test drove and the 3500 we bought wasn't as dramatic as I would've expected. So I bought the 3500 for the extra payload. Either would've done the job. That said, I didn't get a chance to test drive the 2500 loaded, nor did they have one in either flavor equipped with air ride. If you can find one of those, I'd be interested to know the difference.
- Nicholsfamily05ExplorerWe made the switch about a month ago now.
Went from a 2012 mega cab 2500 Hemi to the 2016 crew cab 3500 Cummins.
Both short beds obviously.
But haven't noticed much difference in the rides.
We live off of a really well driven road( beat to death)and then a dirt driveway.
Just over 1000 miles on her and like we said its nothing noticeable in ride I'd say. - DakotaDadExplorerI just made that swap this weekend, going from a 2014 2500 6.4L with the coil spring, to a 3500 Cummins. Both are SRW short beds.
The 2500 did ride better, but the difference was not as dramatic as I expected. The 3500 is not the "crashy" lumber wagon of one-tons from years ago. It's stiffer for sure, but still pretty well composed. Then again, I've had it for only three days, and haven't hit the worst local roads yet. Final outcome still pending.
But it IS worth trying both out. So far, I've been pleasantly surprised. Hopefully that impression holds up over the long run.
44,054 PostsLatest Activity: Aug 13, 2015
