stapler101 wrote:
the trailer I am looking at is a Wildcat 384mb with a hitch weight of 2080 and dry weight of 12443,
I did not know about the door sticker until your post.
My door stickers shows 2380.
Here is my read on this, as one who towed a 12,500# fiver with a 2001 Ram CTD at 1,700# over the 8,800# GVWR.
Will the truck pull it, absolutely no issue there same engine as base 3500. Will you be over GVWR and rear GAWR yes to GVWR, and maybe close to GAWR.
When I finally moved to a 3500 DRW I was 10,500# on the TV, with just shy of 6,000# on the rear axle.
One thing to think about about your choice of 5er, is at 42' it only has a payload of 1,958#, that is less than I have on our 32' 5er!
I see you in trouble keeping both TV and 5er under GVWR.
So lets look at some numbers,
2018 Wildcat 384mb specs
Length 42'
Width 96"
Height 12' 7"
Dry Weight 12,101#
Payload 1,958# (17%)
Hitch Weight 2,059#
GVWR 14,059#
Wet Hitch;
At 17% of GVWR 2,390#
At 20% of GVWR 2,812#
At 22% of GVWR 2,652#
At 25% of GVWR 3,015#
So at GVWR and 17% pin same as dry you are already 10# over 10,000#.
Now that is nothing, but add hitch, passengers, stuff, likely not 17% but closer to 22% for smooth ride you are looking at 11,000# on the TV. Check you tire size, 17" not good only 3,195# each, 18" or 20" you have enough tire.
The reason I chose to step up to a 3500 DRW was not getting cited by a LEO, but being taken to Civil Court by a very hungry injury lawyer.
It is your choice to tow over GVWR, just realize there can be consequences other than a ticket.
