transamz9 wrote:
Cummins12V98 wrote:
ShinerBock wrote:
I hope no one gets your tires for a SRW 2500/3500. Only 3,085 lbs max load for a single? That would drop my rear GAWR from 6,500 lbs to 6,170 lbs.
That's why they got smart and went to 18 and 20's on SRW trucks.
I do wish my front tires had a bit more capacity.
Step up a size or two to give you a little more. 245/75 or 265/70. They are the same height/diameter. Wider and a little more capacity.
Thanks! I will look into those. Since I don't rotate front to rear I could just do the fronts???
