BeMurda
Dec 17, 2022Explorer
Grit dog wrote:BeMurda wrote:Grit dog wrote:BeMurda wrote:
I think I will stick to fiberglass or aluminum types of construction. Lance, Wolf Creek, Northern Lite,
There is a Lance 950S with factory weight 3154 that I really want to look at getting but should probably go lighter. I did order the highest payload Dana rear axle.
You’re not quite understanding the camper construction types.
Aluminum is used in reference to the basic frame skeleton vs wood. I noticed zero difference between our 2 TCs which were identical except the wood one was older and we owned it longer. There’s still copious amounts of wood in most any camper that will be damaged by leaks. If it’s to the point that the frame is rotting it likely already has more damage than feasibly repairable to the other wood components. And even an aluminum frame camper would be basically destroyed due to the “other” parts rotting or delaminating.
Didn’t notice any weight savings or vice versa either with our campers.
The fiberglass were speaking of is clam shell exterior. (which will still have a bunch of wood under it). But it won’t have the full length seams at every corner that are all potential leak sources.
And realize that there isn’t an axle option under basically any 3/4 or 1 ton truck from the last 25 ish years or more that isnt rated to around 10klbs capacity. The axle is actually the strongest part of the truck equation for HD srw trucks. You didn’t get anything special axle wise to figure into your acceptable payload decision.
Yes, I did know all that about the construction, but it is still a good summary thanks :)
Regarding the axle, I'm sure you are correct that they are all rated for far more. What I was referring to is the Dana 4.30 axle increases the GVWR 400lbs relative to the Sterling 3.73 axle.
I also picked the 18 inch wheels and AT tires with the highest rating from the factory.
Actually you don’t understand any of it if you think deeper gears increases payload.
You could easily haul a 4400lb Truck camper around on a 30 year old F350 with a 351 Windsor and whatever gears they came with.
And 18” OE rims dont carry any more than the 20s.
You’ve ordered a very nice truck, congrats and good luck with your search for a camper.
Not sure where that tone came from, no, I don't think deeper gears increases payload in and of itself. On the 2023 F-350's, opting for the Dana 4.30 axle over the Sterling 3.73 axle, with the right tires, increases the GVWR by 400lbs. In fact, it's the only way to get the 11,900 GVWR package.
44,056 PostsLatest Activity: Aug 03, 2021
