kennard04
Jul 21, 2005Explorer
maryb1976 wrote:
I would like some info on the Ford V10 vs the diesel. My husband and I are buying a new truck to tow a toy hauler.. I've heard different stories on each. Does anyone have the Ford F-250 V10? or the diesel. Can you tell me what gas mileage you get.. empty and full? V10 or diesel.. Thanks!!!!!
I get 12-15 solo, depending on how many kids in hot rods I have to show what 'real motor' means. I get 8-11 towing depending on hills, altitude, etc. I would say if you're going to be towing alot, for many years, you will get more out of a diesel. I do not tow full time so a diesel wasn't a good choice for me. Typically you'll get 2-5 mpg more in a diesel. But for very heavy loads, and lots of towing you'll be happer than with a gas motor. The gas engine will tow whatever you buy, but it will work considerably harder at it's tow capacity. I tow around 10K, and the V-10 is a monster for that weight. It's smooth and quiet and very fuel efficient for a big, hard working truck. Drive both, see which one you like, then sit down and figure fuel mileage, fuel costs (diesel is alot higher out here), fuel availability and higher initial buy in costs. At 100-150K miles you should break even with the gas motor for cost. If you buy a new truck every few years you need a gas motor. If you will keep your truck 10 years a tow only, or mostly with it get the oilburner.
44,061 PostsLatest Activity: Apr 08, 2026
