rrnelsonjr
Jul 17, 2009Explorer
Tankerhank wrote:
... the ignition of a explosive fuel/air mixture. Unless you have a flux capacitor... then platinum.
May the swarts be with you.
And one of the results of the explosion is heat. The other is the rapid expansion of gasses resulting in the forcing down of the piston which, in essence, results in horsepower. Horsepower does not create heat.
I do agree with you that the heat is not caused solely by friction. If my engine created that much heat from friction alone it would weld itself together.
44,056 PostsLatest Activity: Jan 12, 2020
