Buzzcut1 wrote:
best thing I do is open the hatch to the first position which keeps the plex from cooking because it has airflow. I have a 1" thick rectangle (cut to match the hatch size) of closed cell foam that I pop into the hatch opening just above the retractable shade. nothing to hold the heat in around the plex and no heat gets through the 1" foam and into the camper.
Thank You! Is the foam white to reflect the heat?
So you are leaving your hatch open 2cm to 'ventilate' according to the instructions?
What about dust, critters, and rain?
