coolmom42's avatar
coolmom42
Explorer II
5 years ago
Reflectix on window, long-term?
I want to block the rear window that's over the bed, in the rear corner of my motorhome. Is there any issue with fastening bubble layered Reflectix to the inside, and leaving it there indefinitely?
My main concern is excessive heat buildup between the Reflectix and the window, that could crack the window. The plan is to block up this window, remove the valance and shade, and install a faux headboard across the wall above the bed. I don't want heat buildup between the headboard and window, thus the Reflectix.
I like to sit up in bed to read or work on a laptop, and the window and shade are just a big nuisance. There is another large window on the side, so there will be plenty of light remaining.
If not Reflectix, what else would work that would look decent from the outside, and block incoming heat effectively?
