Re: Tongue Weight calculating
You can take two bathroom scales and place them under the tongue jack with a 4X4 board between tthe scales. Lower the tongue jack onto the the 4X4 and read the scales, add the amounts together to get your tongue weight. Be sure to subtract the weight of the 4X4.
Keep in mind you'll need scales with 400 pound capacity and the result you get may not be 100% accurate.
The dealer or the manufacturer will have the tongue weight.
No RepliesBe the first to reply
