Turtle n Peeps wrote:
Exactly. So as a rule I'd expect turbo-charged engines not to need to much gearing because of their low-end torque. For some reason though the 5.7 Hemi felt faster off the line than the Ecodiesel even with the same transmission/rear end ratio and with less torque down low.
Because the Hemi has WAY more HP.
Well, that's why it is faster to 60, but that doesn't account for off-the-line feel. HP is just a mathematical function of torque and rpms; it only has more HP because it revs higher. At 2000 rpm, the diesel is putting out 160 hp. With the hemi's torque peak higher and losing some due to my elevation, I estimate that it has at most 120 hp at 2000 rpm. This makes me question the diesels specs.
