monmil's avatar
monmil
rear axle ratio change better towing capacity
Hi,
In great need of help.
We have bought 2 years ago a 2007 silverado 1500 crew cab standard box 4.8l V8 with rear axle ratio of 3.23. Last year my parents gave us their dutchmen four winds trailer which has a unloaded weight of 4234 pounds ( says in the manual that tongue is included in this number)it is also equiped with a weight distributing hitch and sway bars. Having said that, this is our situation. We attempted to go on a fishing trip in LaVerendrye parc last year which is equivalent to crossing the adirondacks in regards of hills. My hubby is a mechanic but has no experience in towing travel trailers. I was towing the boat with my van and he was towing the trailer with the truck. After a few stops he said that he was about to let the trailer on the side of the road, that is how bad he found the truck to struggle up hills. With the gas pedal almost on the floor and in 3rd the truck was still loosing speed in those steep hillsand the engine was running pretty high. My father who is accostomed to towing said that it was pretty normal going up steep hills to drive at 35-40mph. My hubby says the problem would be resolved by changing the axle to 3.73. My question is since he is not experienced in towing is he just scared for nothing and all above details are normal?
here are some specs:
The trucks max loaded trailer weight rating: 4500 pounds
The trucks real weight with all occupants ready to travel: 5600 pounds
trucks gcwr: 10000 lb
trucks gvwr: 6900 lb
trailer loaded weight: 4500lb
trailer tongue weight 650lb
Note that we would travel maximum 2 times a year making 2200 miles round trip from montreal to myrtle beach going thru the Adirondacks
Hope someone can help us
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
