Bobbyg2013ExplorerFeb 02, 2016rear axleMy 2014 Dodge Ram 5.7 hemi has a 3.92 rear axle ratio. Would I be good to pull a 26' travel trailer with a dry weight of 4800. I put between 700/800 pounds of "stuff" in the trailer and another 300 ...Show More
rbpruExplorer IIFeb 02, 2016How do you relate axle ratio to safety? Unless you mean transmission stain.Does the Ram have a towing package? If so, the axle ratio should match the load rating, if not you have other problems.
Related Contentrear axle gear ratioFreightliner Rear Axle Hubcap RemovalRear Axle WeightRear axle ratiosRight rear leveler not retracting fully
