mikeschu42 wrote:
I've been looking at the Aerolite 282DBHS that has the bunk lift system and a rear door. I really like the bunk lift function and the ability to store bikes/other gear in that space. I believe that for 2014 the bunks were only rated for 150lbs, but the 2016 model I saw at a recent RV show had them listed at 600lbs. At 150lbs, the bunks would be almost useless, so I was happy to see the weight rating was increased.
I also remember seeing one other model with the bunk lift system which had a side facing door instead... can't remember the model. Point is, if you search for the bunk lift system, you're likely to find the cargo door as well.
The only difference between the 150 lbs bed rating and the 600 lbs bed rating (actually I thought it was 300 lbs) is the thickness of the plywood on the bottom of the lift beds. Change the plywood (which takes about 5 minutes) and you change the weight rating.
