swimmer_spe
Sep 08, 2015Explorer
Rebuilding a rotten wall (or 2)
So, my trailer is worse than I thought. Basically the back end on the driver's side is rotten to the sheet metal.
The roof seems solid. I have put down plywood, and now the floor is sold enough to stand on.
My exterior wall on the driver's side and the interior wall that houses my fridge and furnace are both rotten. Basically, now that no more water is coming in, it is drying out, and the wood is now turning to dust.
Anyone ever rebuild walls without removing the exterior metal sheeting?
I was thinking of making a wall following the frame holding the roof up and then using wedges to jack op the sagging section.
It looks like the singular interior wall is the issue, and if I remove my fridge, rip out the old wall and rebuild it, without removing the furnace.
This trailer cost me nothing to get. It is not being moved again. So, any work I do to it just makes it better.
