JRscooby
May 20, 2021Explorer II
Lots of difference. How much weight? Will there be any movement? How soft is the ground? How long will it set, will water/plywood cause problems? Do you want the load to slip on the plate?
Under the front jacks will running over the bases cause issues? If so, that plate must be larger to hold off-center load.
