I connect my electric Happijacks (and everything else in my TC) directly to the battery, not to the solar controller load terminals. The high current needed for the jacks is for a relatively short time and I want to be able to use the jacks without the solar controller interfering....as it would if I connected the jacks to the LVD-controlled LOAD terminals.
I agree with you on the use of the LOAD connection. I'm not questioning your comments at all. This is for the original poster....
This is from
Northern Arizona Wind & Sun (my source for solar equipment):
"What is a Load, or "Low Voltage Disconnect" output?
Some controllers also have a "LOAD", or LVD output, which can be used for smaller loads, such as small appliances and lights. The advantage is that the load terminals have a low voltage disconnect, so it will turn off whatever is connected to the load terminals and keep from running the battery down too far. The LOAD output is often used for small non-critical loads, such as lights. A few, such as the Xantrex C12, can also be used as a lighting controller, to turn lights on at dark, but the Morningstar SLC lighting controller is usually a better choice for that. Do not use the LOAD output to run any but very small inverters. Inverters can have very high surge currents and may blow the controller.
Most systems do not need the LVD function - it can drive only smaller loads. Depending on the rating of the controller, this may be from 6 to 60 amps. You cannot run any but the smallest inverter from the LOAD output. On some controllers, such as the Morningstar SS series, the load output can be used to drive a heavy duty relay for load control, gen start etc. The LOAD or LVD output is most often used in RV & remote systems, such as camera, monitor, and cell phone sites where the load is small and the site is unattended."
Just fyi, that's all.
Skipro3, what kind of solar powered equipment do you deal with? My experience is with remote telemetered seismic monitoring stations.
