d1h
Oct 21, 2020Nomad III
Regular or premium
I know that Chevy recommends premium gas in the 6.2L engine. What do all of you out there use? Is using regular a bad idea?
noteven wrote:
Modern auto engines do not ping - knock detection adjusts timing and fuel to prevent any pre-ignition or detonation.
So when you buy an engine that is designed for 91 and you use 87 or less in it will run fine. It is not producing the power you paid for is all. Sometimes the vehicle will use more 87 per mile than 91, especially if you are tow / hauling and actually using max power.
MitchF150 wrote:
I've actually started running premium in my 13 Eco for the last 2 years now and towing my #7000 TT now compared to the old #5000 TT it makes a world of difference..
I just keep it going when not towing too.. Truck seems to really like it, especially with 93,000 miles on it now.
It's getting the best mpg's it's ever gotten not towing. Same route, driving the same way..
I towed my new #7000 TT the first time with 87 in the tank... It was a dog. Thanks to the knock sensor, it ******* the timing so much, it had no power to haul the new beast the way I was used to with the old trailer..
Remember, you just can't dump a half a tank of premium in and expect night and day results. I ran at least a full tank of premium before I towed the new trailer the second time on 92. It was a night and day difference for sure. Well for me anyway.. Your mileage may vary.
My owners manual for the Eco says it'll run fine on 87. But, if you tow heavy, they recommend running 92.
So, no idea on your 6.2.. But, I would say that if the manual recommends running "premium"... I'd go with it.. :)
Good luck! Mitch
