treyster
May 28, 2020Explorer
1320Fastback wrote:
Love this AC, have the same one.
Maybe the gasket? If the 4 big mounting bolts are loose they might just need a turn or two to compress the gasket more. I just swapped our Atwood onto our bigger trailer from our smaller one and the big bolts were not as tight as I thought they should be.
I'll update this thread in a couple of days and ask some advice. Yes it's the gasket and I did add a half turn to the bolts.
The AC drain holes drain right on the outer edge of the gasket. Water was running out the drain holes and running down the gasket then seeping into the interior.
More updates coming
44,066 PostsLatest Activity: Apr 16, 2026
