Boatycall's avatar
Boatycall
Replacing that big rubber seal on a slide out
How much fun is involved in replacing the large rubber seal/flap that seals your slide when it's open?
I just noticed today at the top of one of those it's beginning to tear. It has about 2" at the top that have started to come apart.
  • Phancy wrote:
    I did a temperary fix on mine about 10 years ago using super glue while we were in Yellowstone, still holding strong after many uses. I check it often no sign of failure.
    Interesting. The thought of maybe using a vulcanizing liquid and a patch piece cut from a rubber bicycle tube came to mind.
  • I did a temperary fix on mine about 10 years ago using super glue while we were in Yellowstone, still holding strong after many uses. I check it often no sign of failure.
  • I need to use my camper more!
    Only thing worn out in 13 years is the batteries and the asphalt where the jacks sit!
  • For me, the hardest part was taking the old seals off. Putting new ones on was a snap.
  • Not bad.
    For the future, lubricate it with baby powder. This provides some ability to allow the rubber to remain pliable and not stick, the cause of most tears. Once or twice a year is all you need.
