Spade_Cooley's avatar
Spade_Cooley
Road trip and two blow outs on Goodyear Marathons
A year and a half ago I bought new Goodyear Marathons (14 inch "D" rated) for my 27 Foot Crossroads Sunset Trail TT. I took a couple of trips on them putting on around 8K. I recently took a trip to Idaho to visit family and the tires looked fine. I had kept them under cover and aired them up to the desired 50 psi. The trailer had also been stored up on jack stands. On my second day out I have a blow out on the left front of the travel trailer on I 80 near York, NE. I change it and go to my nearest Walmart to get a new tire. I have it changed and the next day north of Ogden, UT I have another blow out on the other side. I end up spending the night in the Walmart parking lot awaiting the opening of the tire shop the next day when I got all the tires replaced. I'm now riding on four new Good Year Marathons because that was the only trailer tire they carry.
During my trip which is now over I have four lousy unsafe tires on my trailer. Before I take another long trip I will remove the Good Year Marathons, "D" rated trailer tires and replace then with either a truck tire or get a better quality "E" rated trailer tire. The tires came apart just like a cheap re-cap tire. Any ideas on what I should switch to?
  • The tires came apart like rubber peeling off a cheap re-cap. I didn't hit anything. The tire says to inflate to 50 psi which I did. Not going to buy the Goodyear brand again.
    The first blow out took off my plastic wheel cover but my second one didn't do any damage.
  • Check the date stamps on the tires, even "new" ones. They will give you any in stock, or possibly the oldest!
    I wouldn't take if over a year old! Walmart may exchange if yours are old.
  • I would say you underinflated your tires also. Here's the Goodyear inflation guide.
    http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
  • Bad luck and hit something in the road?
    Once they blow, they can quickly shred and it looks bad.
