rbq
Aug 18, 2014Explorer
Open the outside fridge compartment. Look at the right side for a tube running up. This is the vent tube. On this tube there are two wires connected. Between the two wires is a small resetable circuit breaker. Stick your finger between the two wires & push. If have have had no lights on the fridge panel & no light comes on when you open the fridge door then this is one of the likely fixes by pushing that circuit breaker. This protects the fridge for overheating if out of level for too long. Hope this works. Learned this from my own problems with the fridge not working. It's worked fine since then.
