mileshuff
Sep 27, 2018Explorer
I pulled a very similar Hybrid, a StarCraft 21SSO. Same floorplan and similar weights. I pulled with a 2004 Durango 5.7L V8. It pulled quite well but I would never consider pulling with a V6 (Had a Nissan XEV6 as well). Would also not consider pulling with a smaller, less rigid framed vehicle.
Even the smaller hybrids that weigh in loaded at around 4,000lbs would be a bit much unless you live in flat lands. Then they're a possibility. I used my Nissan V6 truck to pull a 2,500 lb loaded popup which worked very well.
