Blackdog79's avatar
Blackdog79
Roof Repair
Had started the restoration process of my '79 Coachman little over a year ago, Sadly as I started pulling out the interior I found that the only thing any good was the aluminum shell so the project was scrapped. Picked up a 95 Prowler 27x for a good deal. Now, thanks to the lovely winter we had in PA I have a hole in the left front corner of the roof, two broken ceiling joists, and a cracked top rail. Thankfully I can back it inside my shop to be able to work on it but still a mess. Now to my question... I am going to cut the first 7 feet of the aluminum roof off to give adequate access to the joists and hopefully be able to tie in a patch plate on the top rail. I can get a 4x8 sheet of aluminum from a local supplier for $34. Was planning on using roof sealer caulk and pop rivets to install the patch, as well as caulking the seam from the inside. Once caulk is dry next step is to be eternabond tape around the entire patch. Does this seem to be a sound plan? Also what is a recommended coating to go over the patch panel since it is bare aluminum, as well as coating the rest of the roof while I'm up there? I'm hoping to get this taken care of for around $500 if possible.
