captainkirk1856's avatar
May 12, 2016
Roofing questions.
I have 2 TTs, due to finding one with lots more room, quad bunks, and having a better TV. My other trailer sits idle, and I have several ideas of renovating it down the road. I have researched and tried to find as much info as I can on options. This topic relates to the roof.
About 2 years ago, we discovered some nasty water damage at the back of the rig. We ended up taking the siding off, and rebuilt the entire back wall, part of the front wall, about 8 feet of floor, and some of the roof, including 4 beams. Definitely a learning experience, but it's nothing I would be scared of if I had to do it again. It has the EPDM roof, same roof since it was built in 2006. I know I could do a new roof job with afresh roll of EPDM rubber, but I was wondering what else there is and how it works.
I know about TPO, similar is some ways to the EPDM. I have a metal shop nearby that I could likely get a full, one-piece sheet for the roof. How does a roof like that translate to the molding across the top of the trailer that covers and holds the rubber roof in place? The rubber roof folds over the edges and that molding is attached through the rubber, and into the wood at the top of the wall frame. Would the aluminum fold at the edge and go there also, then have to be sealed with lap sealant as it currently does? At the front, would it just be screwed down and then have sealant blobbed there as well? I have tried to find pictures of cargo trailers, semi trailers, new and old RVs of various types, just to get a glimpse at how it is done.
Anyone with experience or own something with a metal roof, any pics and advice is greatly appreciated. Thank you.
  • The metal roof sounds interesting. I used commercial rubber roofing purchased from Harvey industries (a nation wide building supplier). The dealers I called all wanted at least $700 for twenty five feet of roof material, Harvey was $225 for the material and a five gallon bucket of adhesive. The RV specific roofing material was .007" thick the product from Harvey was .035" thick. Three years and no issues yet.
  • Look into RV-Armor. It appears to be similar to bed liner, applied to the roof. Someone here got their rig redone in RV Armor and loved it.
