JaycoAngel's avatar
JaycoAngel
Rookie Diesel Owner
Posting this for my hubby:
I recently bought a 2014 GMC Duramax Diesel. Previously pulled
With a big block Chevy. Not sure what gear to use when pulling:
Drive or Manual and I am not sure about the tow button (I am assuming
I use the tow button (I am assuming whenever I am towing).
Would appreciate any advice.
  • Use the towhaul button when towing or any other time if you wish.
    Truck will pick the right gear, but if you don't like how it's hunting gears, drop 1or 2 with manual mode. If the truck will hardly accelerate at all in the gear you're in, likely rpms are low, drop a gear.
    You'll be amazed how easy it tows compared to any big block gasser.
  • spoon059 wrote:
    Put it in drive and let the Duramax and Allison do what they do. Its a great combo and a great truck. Tow/haul will hold gears a little longer, which helps when going up hills.
    Stay on top of maintenance, change your oil and fuel filters according to your manual. You'll love how the diesel pulls!
    X2.
    Your diesel will put a big block gasser to shame. The torque just seems to be endless.
  • Put it in drive and let the Duramax and Allison do what they do. Its a great combo and a great truck. Tow/haul will hold gears a little longer, which helps when going up hills.
