okan-star
Apr 04, 2014Explorer
Im guessing you have atwood electric jacks with switches on the drivers side , 2 on front 2 on rear jacks? So you cant raise the jacks all at once ? If that's true raise the front first , but only about 3 inches , then do the rears so its level , then the front again , always keep the front higher than the rear , going up and down
Sounds like you just may have been raising one end to much past the other
Put some 6"x6" pieces of plywood under the jack feet , that will keep the jack feet from sliding on the asphalt
You may want to later on think about a new wirless controller for the jacks,like a GAMA unit, You do have to rewire the pas side jacks separately from the from the drivers side jacks to the controller . and ditch the switches , you can get blank lower covers w/ out switch holes
Then you can walk around and watch as the campers going up all at once
If you have manual crank jacks , same thing one jack2 or 3" at a time always keeping the front higher than the rear
