anaro
Sep 15, 2014Explorer
Yes you can unplug and blow on the connections and try plugging in again. Then test the output from the truck to see if you have power coming out at the pig tail receiver (7 pin connector) if you have power coming out for all pins then the fuse or tv is not the issue. Then you need to be looking at the tt.
44,070 PostsLatest Activity: Sep 18, 2026
