RedRocket204
Jul 20, 2013Explorer
peirek wrote:rlhay wrote:
The gfci outlet and one other one stops working when tripped.
I have 3 outlets that are not working, under kitchen cabinet, outside, and one other in dining area.
And I think maybe you have another GFCI outlet hiding somewhere? With the circuits around the kitchen sink involved in the mystery no power, it is causing me to draw this theory. Also, reading some of the other comments in this post.
The 3 that aren't working could also be the down stream outlets, all on the same circuit, which has lost its connection at an outlet upstream of the non-working outlets. Problem is finding that outlet where the wiring has become very loose or disconnected.
I would probably be removing all outlets until I found that loose wire, making sure you aren't connected to shore power first. The other option could be if the wire was cut behind a wall from drilling or ???
