UTCoyote
Jul 21, 2013Explorer
FWIW... I have a similar problem. Only a couple of my outlets are working, the GFCI in the bathroom and the one for the microwave. None of the others are working, including the one the fridge plugs into - so it only runs on gas for now.
I've searched and searched, inside every cupboard and compartment, I can only find one GFCI reset, in the bathroom - and that's one of the outlets that DOES work.
I have pulled a couple outlets out of the wall, and it does appear that they are all connected. So I think I probably need to pull them all out and find out where the breakdown is.
Sounds like you might have similar or same.
Although, mine are exhibiting additional strangeness, so maybe not. I say they aren't working, and they are not. But, when I put a meter in one of them to check, it will show 190 volts once in awhile, other times show only 4 or 5 volts right at first then quickly go down to 1 volt. Just shows zero most of the time.
- Coyote
- Coyote
