rlhay
Jul 21, 2013Explorer
May or may not make a difference but the red cable on your multi meter should go in the smaller slot in the receptacle, this is the black hot wire, can't tell if it is correct in the picture. Sometimes if cables are backwards this will give false voltage readings. Put the red cable in the small slot, black cable in the larger slot and check voltage. Then move the black cable to the round hole in the receptacle, this is the green ground wire, and check voltage. Something is bad wrong if you get 190v.
