kzspree320
Jul 11, 2017Explorer
Payload label will be somewhere inside the drivers door jamb. The payload, maximum for people and cargo (which includes 5th wheel pin weight), should be approximately 2,800-3,000 lbs.for a gas truck If you have the Vortex V8 gas (I assume), the maximum 5th wheel towing (which is more than conventional trailers) with the 4.10 rear axle is 14,300 lbs. I would try to shoot for a loaded weight of less than 12,500 lbs or I think you could be disappointed and over your rear axle weight rating of 6,200 lbs. The Montana you are considering is too heavy in my opinion. (My data is from the Chevrolet website and assumes standard crew cab gas truck). Good luck.
