gbsb's avatar
gbsb
Scan Guage
I have a 2003 Ford F450 with a 6.0 diesel. Does anyone here use a scan gauge 11 for monitoring their engine. I would like to monitor motor functions as we travel. Voltages, EGT, oil pressure, and so forth. Thanks
  • I use the SG2 to monitor FICM output voltage, High pressure oil to the injectors, Transmission oil temperature and Engine oil temperature on my 2005 6.0 PSD.
  • I had one on my 6.0 and it saved my motor. Was able to see the large difference in deltas with my oil and water temps, shot up to 45° spread. I had mine set for water temp, oil temp, FICM voltage and tranny temp. Great investment for $120. Check out there website for all of the codes for the 6.0. Good luck.
  • I have an edge insight CTS. You can monitor up to 10 points at the same time and set it up to alarm at specific points. For the EGT you will have to drill and tap the exhaust manifold. Other than that it just plugs into the OBD port under the dash.
  • I have a 06/f350. Installed a scan gauge2 , I like it.
    I have it set for oil temp,water temp,tach and voltage. You can reprogram this as you like. There are lots of other stuff you can monitor. I believe to monitor EGT, you need to buy a probe and have to drill the exhaust pipe. Others may know more about this, or go onto scan gauge's web site and search for what you need. I know with the 6.0, water temp and oil temp are critical.
  • I`m using my I phone and the Dash Command APP from I tunes. I believe with other phones it the Torque APP, similar to Dash Command. I really like all the parameters it gives. it also lets you erase codes even performance numbers and such!
  • We just bought one for ours so we can watch the tranny temp as we partially covered the grill. Haven't tried it yet as the motorhome is up North and we are down South. Currently using it on the smart car for fun. On the brighter side according to the scan gauge my around town gas mileage (technically diesel mileage) is 53 mpg. :) Kinda knew that already but its fun to watch numbers. Think they'll drop a bit on the motorhome. :)
  • I would look at the app called Torque Pro. It reads codes as well as live data and show your choice of gauges.
    I use it on my 3 diesel Powerstroke engines
    Torque Pro
  • I use Scan Gauge II on my 7.3L diesel. Can be set to monitor almost anything you eant. However you may get readings that are normal that may cause you to worry because you didn't know about before.
  • Here's a recent thread on the topic. I use a Bluetooth adapter and my smartphone. Don't know about diesels.
44,030 PostsLatest Activity: May 01, 2025
