marquette's avatar
marquette
Scangauge vs Ultragauge for trans temp.
I know several members on here are using the Scangauge to monitor trans temp but I was wondering about the Ultragauge and how it compares. It's about half the cost and I like the way the display is lighted better. I have a 2001 1500 Suburban 5.3 with tow package but no trans temp gauge like the 2500 has. It's easy and affordable to retrofit 2003 and newer but about $250 to do a 2001 so a OBII gauge seems like a reasonable alternative if it will work. Any thoughts on either will be appreciated.
  • Desert Captain wrote:
    lbrjet wrote:
    Golden, my Scangauge does everything you mentioned and more.
    X2 For less than half the money.
    :C
    X3 I use it on my F250,even though it has a temp guage
    :C
  • Golden, my Scangauge does everything you mentioned and more.
  • Do you have an Android smartphone? I use this OBDII Bluetooth reader with the Torque Pro app on the Google Play store. Less than $30 for the combo and can read more than what most of us need. Tach, speed, coolant temp, accelration rate, MPG, and other things. Compare before you buy.
    Out of the box it does not monitor trans temps, but you can add custom gauges if you can find the right PID for your truck. But just as ktmrfs said, not all vehicles have that available. My truck has a trans temp readout so I don't need it in the app.
  • I bought a Edge gauge at Amazon.com for $310. I looked at the scan gauge, and wanted more features.
    I can monitor cylinder head temp, transmission temp, coolant temp and many others. It also monitors MPG and I wanted to monitor RPM on the 2001 van that I bought without a tach.
    I know - more expensive, but think of it this way. It can me moved from vehicle to vehicle, and can also check all the engine codes too.
    Fred.
  • haven't used the ultraguage, but have the scangauge in 3 vehicles. If you want to measure transmission temp with the scangauge just make sure that the vehicle you have has codes for the scangauge to support transmission temp. not all vehicles do.
