Cummins12V98
Dec 21, 2013Explorer III
Drop your air pressure to 45 in the rear when not towing. When loaded weigh your TV's axles and use weight/inflation chart to determine proper inflation. Example on my RAM dually I run 60 in the rear with 4,500# pin weight. Bilstiens will help a lot. Get the yellow and blue ones from Genosgarage.com. Also air bags will help even out the bumps. I run mine at 30psi loaded, it does not change the ride height at that psi but does help with the jarring.
44,066 PostsLatest Activity: Apr 10, 2026
