Gdetrailer
Dec 21, 2013Explorer III
Nothing short of replacing the one ton truck for a 1/2 ton truck is going to "fix" a stiff ride..
You have had this same vehicle for 80K + miles, should have noticed this from day #1 of ownership...
I would suggest if you are running full sidewall pressure while unloaded then lowering the pressure SOME WHILE EMPTY ONLY will go a long way in making a firm ride a bit softer, BUT it still has 1ton SPRINGS and they are stiff.
While it may be possible to slip softer springs on the vehicle then you are going to risk overloading those springs when loaded.. A catch 22.. You can't have both worlds (Caddy ride when empty AND 1 ton hauling)...
It IS a truck and heavy haulers DO ride harsh especially when unloaded.
44,066 PostsLatest Activity: Apr 10, 2026
